1/8 combo
Got a question . I got a rc8be and wanted to know witch combo.will be faster on 4s. Lhs only has a mmm 2200kv and a rx8 2050kv in stock. Thnx.
Both of those are going to be fast...gonna come down to which brand you like better. I personally use Tekin in my cars but I use Castle in all my aircraft.
2200kv is a little more powerful but the trick is puttng the power to the ground. |
The MMM and 2200 is a beast but still non-sensored. I run the MMM and 2650 an once in awhile it will cog. Have no experience with the tekin system but I have heard it is nice and it is sensored so it should be smoother. Tekin was just a little out of my budget but I see alot of people use them.
Are you buying this for just bashing or will you be racing? If racing, both motors are a lot for e-buggy. Also, you want sensored for racing, so that throws out the Castle setup.
I would recommend the following 4s setup: ESC: http://www.falconsekido.com/products...c-for-1-10-car Motor: http://www.hobbyking.com/hobbyking/s...or_1900KV.html Half the price of a the Castle or Tekin setup and just as good. |
Originally Posted by 2fat
(Post 11683409)
IMO, LHS support stops when they do not carry what you want. By all means if he wants one of the two setups his LHS has then supporting them is a good option (if they are a good LHS). If he wants a different setup that they do not sell, there is no "bad karma" with ordering off the Internet. Only purpose of my post was to let the OP know there are setups that cost a lot less than the Tekin or Castle setup, no matter where they are purchased.
According to your previous post(last month)you said you allready have a MMM and 2200? Did you get rid of it and getting something new?
Originally Posted by huzzler
(Post 11684845)
(Post 11684619)
I believe he is trying to support LHS?
(Post 11685179)
Want to support the lhs but the combos are 350 bucks. Wtf
| All times are GMT -7. It is currently 11:47 PM. |
