Servo issue with m11x
I have the m11x and a 92744 receiver in one car, works fine. I bought a 92451 for another car, copied the profile over from the one car, and set I up with everything 100 percent and zeroed. The throttle works as it should, but the servo centers and won't move. I checked the servo hooked up to the 92744 receiver and it's fine. Hooked up a different servo to the 92744 and same issue, it'll center but not move. Any ideas?
Originally Posted by Chris Brown
(Post 11680914)
I tried that. I even tried other servos and nothing. Plugged the speed control in to the servo port and it worked fine. Gave up and took the receiver to airtronics. Hopefully they can figure something out.
do you have your steering servo set in shr or normal mode on the radio?
Shr. I tried it in normal and shr, no difference. And the servo works fine in my 92744 in shr mode.
(Post 11705690)
(Post 11705690)
Yeah. I binded the receiver numerous times. Even after plugging the esc in to the steering port. Just to make sure.
| All times are GMT -7. It is currently 02:38 PM. |
