Please Help! Don't want to burn my house down!
I recently got (2) Losi 2s Lipos with a crawler I bought off this forum and had to change all the connections on them because my charger (brand new Thunder AC6) did not have the right adapters.
---I changed the original EC3's to 4mm bullets which I know I did correctly. The part I am not sure of is the balance connectors. I changed the original ones on the Losi lipos (forgot the specific name of them) over to 2S 3-Pin JST-XH and I think I might have the balance wires mixed up. ---I plugged the Balance connector into the board and a small puff of smoke came from the board and the copper band/wire linking the #1 wire (black, at the top of the board) to the 2s balance connector popped out from the board and snapped. http://i771.photobucket.com/albums/x...pse0d12bb5.jpg ---When I changed balance connectors to the JST's I kept all the wires in the same slots. ---Should I have switched the two outer wires so when connected to the balance board the red wire would be toward the bottom connecting with the #3 wire on the balance board (the only red wire on the board)? :confused: I had it like this and got the puff of smoke. http://i771.photobucket.com/albums/x...193715_580.jpg Should I switch the outer wires around so the red and the black line up with the wires going to the board like this?: Seems like a dumb question but I don't want to fry another balance board. http://i771.photobucket.com/albums/x...193802_059.jpg Please Help I am new to this and switching out the balance connectors on these Lipo's seems to be a little over my head. Especially since I have never used Lipo's before. Thanks |
wire #1 is your ground.
Your black and red wired are backwards. https://sites.google.com/site/tjingu...ce-connectors/
So I am guessing that I should leave the middle wire alone since it was in the middle of the old connector and switch the 2 outer wires.
----Is this correct? ----Does the middle wire serve a purpose? I read the link above, but it really didn't specifically cover this. He says he's not going to get into the specific wiring differences between the connectors. I want to get this right so I don't ruin another balancing board. Anyone know where to get a new balancing board for the Thunder AC6?:o http://i771.photobucket.com/albums/x...ps3a38ade4.jpg |
Originally Posted by joe226
(Post 11669499)
----Is this correct? Probably yes, but I would make sure and use a volt meter ----Does the middle wire serve a purpose? That connects to the link between the 2 cells of the battery. It is necessary for balancing them. I want to get this right so I don't ruin another balancing board. Anyone know where to get a new balancing board for the Thunder AC6?:o Any 6cell jst-xh balancing board will work. |
You know nothing of what you're doing but you decide to just go swapping connectors. What you should have done was BUY THE PROPER SET OF BALANCE BOARDS. You can't screw around with lipo's clown!
Originally Posted by Johnnysplits
(Post 11669914)
100% BS. i was once a noobie with lipo's like ALL of us at one point. I decided to rebuild a 4S that had a cell drop on it. Did i get scared and go BUY a new pack. NO I Screwed around with how to separate the cells and how to unsolder that Ungodly solder they use and managed to make a perfectly good 3S 5000 Out of a 4S. I also made a balance boo boo a while back Left a ThunderPower balance board in line when i plugged in a JST lead further up line....Smokes the balance wires and luckily i was quick enough to disconnect before anything else happened. Lesson Learned...One board at a time.:lol: |
If you have a quality charger it will sense reverse polarity on the ports as well as an incorrect balance board or bad balance connector. My Podigy Duo 620 does this.
(Post 11669499)
Integra - Good for you...maybe you should make a side business out of it.
EricW - Like you state "if you have a quality charger" Most people don't understand the need for a high quality charger over the cheap junk that they have. |
Originally Posted by huzzler
(Post 11670252)
Don't worry about what other people say about messing with Lipos. At least your not a puss and have the balls to try unlike this other guy.
(Post 11669914)
(Post 11670287)
(Post 11670313)
Not into burning my house down. I educate myself before doing things I know nothing about.
Ultimately they just have to be wired like this. I've seen many colors backward, and numbers reversed and balance boards reversed from std.
MY std is to start at the neg most side and call that cell #1 and pin #1. This is pretty much the standard on most all packs and chargers and boards. This is also the black wire. http://www.scriptasylum.com/rc_speed/lipo.html Hit 2s and show balance wire hook-up. |
One side suggestion I have is always check new lipos with a DVM to make sure they are wired correctly before connecting them to a charger. I actually got a lipo once from HobbyKing that had the balance wires reversed. Looked correct on balance plug but the wires were soldered opposite of what they should have been on the pack. Only way I knew about it is I connected to to my little cell checker before trying to charge it the first time. After that, I make sure to use the cell checker first on any lipo I buy.
Originally Posted by kcobra
(Post 11670570)
Thanks to everyone else for being extremely informative and helpful. I kinda figured I would get some negative responses considering the title of the thread. Didn't really think I was going to burn my house down, I just wanted to be sure of what I was doing. These days you sometimes have to use a catchy title to get people interested in otherwise boring threads. |
