-   -   Battery Help (https://www.rctech.net/forum/radio-electronics/689831-battery-help.html)
Firehawk548 12-27-2012 09:21 PM
Battery Help
Hi guys im new to the 4s car/truck stuff and have a question.
i have some GenAce 5000 / 50c / 2s batterys with the wires that plug into the batterys.
i just got a MBX6 eco with a Tekin RX8 / 1900kv combo kit for x-mas and i want to run 4s:D
so my question is...will the 4mm bullets that plug in to the batterys carry the load?? 2 - 2s in series
or should i get some batterys will the wires made into the batterys???
whats the best setup to run 4s in a car/truck??
i run 5.5mm bullets in my boats as the deans would unsolder them self and nor shur if that will happen in a car.:confused:
hotrod87 12-28-2012 03:53 AM
I'm not an expert on this one... yet. I just started getting into 1/8 electric and so far I haven't had a problem with deans. My gens ace pack are same as yours and no problems there yet either. Running a 1900kv on 4s in a generic mt.
Firehawk548 12-28-2012 06:59 AM
are you using a plug with the 4mm bullets on one end and deans on the other???
i need to make my ESC wires. so im going to make them plug straight into
the Battery :) should be less resistance
