can someone explain throttle endpoints with ESC?
messing around with my radio tonite and noticed that i could raise my EPA (end point adjustment ) past 100% all the way up to 140%, this brought a couple questions to mind. First when i calibrate my ESC for full throttle/brake/neutral with the controllers endpoints set at 100 or at full 140 will i notice any difference? or will the ESC still recognize that as full throttle? and secondly if i had it set at 100 percent and calibrated my esc with it at that setting would raising it to 140 be causing it to push any more/too much power possibly damaging things? im looking to crank as much power out of my truck as possible and have a temp gun to make sure im not raising the temps too high. any help from the guru's is appriciated :)
im using an Airtronics m11 and a mamba max pro ESC
interesting, so what your guessing is that you would still get the same power but with more control/smoothness? (im horrible with electronics so all the talk of pulse width and such confuses the hell out of me haha:lol:)
hmm, deffinatley hoping someone with an answer to this steps in here and sheds some light. quite curious :sweat:
All of rallyredevo's comments are correct.
Originally Posted by rallyredevo
(Post 11595643)
Can you say that again :-)
Normally I only hear how one thing I said, taken completely out of context, is the dumbest thing ever put on the internet lol. |
so from what i can gather the best setup seems to be set my EPA at about 130%, then calibrate the esc, then crank the EPA up to about 135-140%?
(Post 11596652)
If the rest of the system can use the additional resolution, and you want to use it as well, I would set both EPA at 138 or 139%, set up the ESC, then move both EPA to 140%. I think 5-10% slack on both sides of the trigger would be excessive. 1-2% is probably perfect to ensure full throttle/brake.
insert small *face palm*
some esc's will have an issue with a calibration at less than the radio's max % others will not. NONE will have an issue when the % is set to the max epa. Max out the radios throttle epa % and you're guaranteed to have no issue. |
