aa life batterys
Does anybody know where I can buy aa life battery's?
Originally Posted by sschultz
(Post 11521407)
I do not think they have such a thing. A set of them would more than double the voltage in whatever it is they are about to cook. |
Originally Posted by lbenton
(Post 11521847)
The LiFe battery is 3.3v right? A 'AA' will range from 1.2v to 1.5v.
Batteries plus or ebay
there 3.3 volts and there the same size as a AA battery
i use to sell them but i am not getting anymore till the new year if your williing to wait till mid Jan ill have more no mods need to the radio so if your radio take 4 aa batterys my kit will work for you http://i23.photobucket.com/albums/b4...10509-0226.jpg |
They are hard to find. Most LiFe AA are 3.3 to 3.6v... and only 400mah to 600mah.
Not sure if its a misprint on not, but the numbers on the one Tom posted indicates its an A battery...(and a fat A at that). td, I would think the ones you have would sell like hot cakes! 3v and 1600mah would have so many uses. |
Originally Posted by Ed Anderson
(Post 11534916)
Not sure if its a misprint on not, but the numbers on the one Tom posted indicates its an A battery...(and a fat A at that). td, I would think the ones you have would sell like hot cakes! 3v and 1600mah would have so many uses. & the one I posted... http://www.radioshack.com/product/in...cs#tabsetBasic Look Directly below "add to cart" clink on "See technical specifications " |
Don't get me wrong, I would rather have td's but he was out when we last checked. Just an alt.
Tom, I'm getting 2 different pages from your links, maybe the first was a typo? (the first is 18.1 diameter, 800mAh vs. 600, 18500/14505?)
Appreciate the limks though, like to try some. |
Originally Posted by td-civ
(Post 11529056)
i use to sell them but i am not getting anymore till the new year if your williing to wait till mid Jan ill have more no mods need to the radio so if your radio take 4 aa batterys my kit will work for you Can you let me know when you have some, or do I need to keep checking your site or whatever? Thanks |
They are two different links... Correct me if I'm wrong... but I'm pretty sure the numbers on a LiFe battery indicate the diameter. An 18500 is 18.5mm. A "fat A" is 18mm. The 14500 is 14.5mm... Its a large dia AA but it fits. |
(Post 11535218)
Tom http://www.radioshack.com/product/in...SE#tabsetBasic |
How long could I expect the charge to last in my dx3s?
Longer than regular AAs? Is It possible to put all 4 life cells in stock tray and run 2s2p to double capacity, or would it be better to charge four cells and place two unconnected spare in tray to swap out when first set are discharged ( I don't think I will like the weight of my controller without four cells in it?) Thanks |
Originally Posted by wrongchannel
(Post 11538730)
Longer than regular AAs? Is It possible to put all 4 life cells in stock tray and run 2s2p to double capacity, or would it be better to charge four cells and place two unconnected spare in tray to swap out when first set are discharged ( I don't think I will like the weight of my controller without four cells in it?) Thanks I have a futaba 3pk & I am going to build my own 3s2p pack |
| All times are GMT -7. It is currently 04:32 PM. |
