LiPo battery for transmitters?
hi guys, i have a few questions.
first off, ive been noticing people have been putting lipos into their tx's.
i assume so because it possibly lighter, last longer, and is rechargeable. correct me if im wrong.
anyways my question is as follows:
after use, im sure there's still a good amount of voltage in the lipo, do you guys just leave it or do you guys put it into storage mode after each use? i ask because at most i use my rc two times a week for about 3-4 hours each.
my other question is that what cells are you guys using? is it 2s (7.4v?)
my radio is the sanwa/airtronics mt-4.
ive searched and seen what people are using, but not specifically what is allowed.
any help is appreciated, thanks.
I use a 3 cell Lipo in my 3PK and only charge it 3 times a year. That's used mostly on a weekly basis too. Leave it in the radio and I charge it at 2 amps on any lipo charger. When the voltage read-out on the radio gets down to around 9.5 volts, time to re-charge. Happy with this!!!
Your radio will accept LiPo or LiFe. Some newer radios won't accept a LiPo, like the Futaba 4PKS, but you can use a 2s LiFe. Just check the specs on your radio before you buy a battery.
The Airtronics MT-4 specifies:
Accepts Optional Ni-Cd or Ni-MH Batteries or 2S Li-Po or 2S Li-Fe/A123 Battery Packs
thanks everyone for the replies!
