-   -   Castle external BEC (https://www.rctech.net/forum/radio-electronics/681402-castle-external-bec.html)
hoyt1976 11-25-2012 08:19 PM
Castle external BEC
I recently picked up a Castle external BEC 2nd hand with no instructions. I wanted to use with with one of my MMP's, any info, pics on wiring would be greatly appeciated.
kingkong559 11-25-2012 08:38 PM
Solder castle bec's positive and negative wires to esc's battery connector. Then plug it into an open channel in the receiver.
hoyt1976 11-25-2012 08:41 PM
Reciever plug from the ESC stays plugged in it's normal spot as well?
kingkong559 11-25-2012 08:46 PM
Yes but i forgot to mention that you need to disconnect the positive wire on the esc. I disconnected mine at the receiver end.
hoyt1976 11-25-2012 08:50 PM
Ok, thanks for the info!
td-civ 11-25-2012 11:21 PM
i hope you have a castle link to programe it as you need to set the volts to what you want to run it at as stock volt is 5 volts
