orion- lrp problem
Hi I have a orion pro 2-3s and before I had it with a 6.5 vst but was very slow and I just bought a lrp x20 4.5 but I have a problem, is that the engine is only revs to the middle the throttle suddenly doesnt respond and suddenly works again and revs to the end and suddenly doesnt respond and revs to the middle and do this all the time ... I updated the software of the box and the esc and have recalibrated esc anyone know why that is? i have a sanwa mt4 an orion 90c lipo batteries but with the other motor worked fine
Have you tried a different sensor cable with your new motor? Orion ESC's seem very, very sensitive to the sensor cables. Also, check your voltage cut setting on the ESC - if you raise it above the default 3.0v/cell, Orion ESC's will tend to cut under acceleration and that's even more likely with a motor like a 4.5.
where should I put the voltage cut with the 4.5?
Just double-check that it was left at 3.0.
I´ve discovered that the lowest the lipo cut is the less the car stops but yes at 3.0 it keeps doing it and i´ve tried different sensor wires but keeps doing it too any idea why this could be?
anybody??:cry:
Originally Posted by tomi30
(Post 11479722)
anybody??:cry:
savox 1258 but with the orion motor worked fine..
(Post 11486249)
(Post 11486249)
Good luck with this Kevin |
i went to an electronics shop and I bought a 1000microF capacitor and connected it to the reciver , but it didnt do anything ,isnt enough?? or the ones from amain have something different??
i beleive the spektrum is a 5800uf. but its a 10v rated cap. caps are overrated by 4v typically. try a 16v rated cap.
what program are you running on the r10,stock or modified?
yikes,just noticed the date on the last post |
| All times are GMT -7. It is currently 04:04 AM. |
