Help with Mamba Max Pro SCT
Ok short story,
Was driving around at lunch to show my truck to a friend doing speed passes and drifts on gravel, no jumping at all, no crashes at all... made a spin out and truck stopped. Went and picked it up and it's been doing this: :weird: http://s384.photobucket.com/albums/o...F382730658.mp4 Other weird thing is it does not make any sound anymore when i turn it on or calibrate it. Lights match the calibrating procedure but no sound. Battery is at 11.7 ( 3.91+3.93+3.93 ) 1.38 firmware Calibrated the ESC, batts in the transmiter reads 5.6v, plugged in the Castle link and set it all back to defaults to no avail.... Any help would be greatly appreciated. |
Did you try a different motor? If firmware version 1.38 is a beta version I would reset to a non-beta.
Make sure the wires going to the receiver aren't damage/crossed. Had a similar problem and found that the wires had lost some of the insulation and were crossed making it act funky when I pulled the trigger. But as said above, try a different motor.
Ok thanks, i'll give it a shot tonight with a new motor.
Keep you guys posted. |
| All times are GMT -7. It is currently 06:51 PM. |
