-   -   Tekin 55t comp crawler problem (https://www.rctech.net/forum/radio-electronics/670571-tekin-55t-comp-crawler-problem.html)
turners dad 10-16-2012 01:10 PM
I have a tekin brushed 55t motor that has lost power going foward, reverse is strong still. I recalibrated the mmp and changed the settings with the castle link from crawler to 100% brake with no results.
Do the brushes need replaced or what can I do? I have a very depressed 10y/o boy on my hands here....lol
I looked all over the tekin site for new brushes with no luck, any ideas would be great, thanks in advance
BBJ 10-16-2012 03:30 PM
Have you retarded (negative) the timing on the motor? Any brushed motor that is required to run both forwards and reverse must run 0 degrees timing. If the brushes were gone, it would run poor in either direction.
turners dad 10-16-2012 05:26 PM
I have not messed with the timing on the motor, I will check the speed control. Thanks
turners dad 10-16-2012 05:49 PM
I checked everything on the link, I changed it back over to crawler and right now it seems to be better. I don't know what's going on but I'll run it till it starts doing it again....thanks
