-   -   Sensored motor question (https://www.rctech.net/forum/radio-electronics/670526-sensored-motor-question.html)
travisridenour 10-16-2012 09:52 AM
Ok so I bought a brushless setup and I'm new to it. I bought a tekin 17.5 sensored motor and an Lrp speed control (can't remember the model right off hand) that has a spot for the sensor wire. I did not however recieve the sensor wire in the deal. So my question is will the motor work without it or do I need to buy the sensor wire to get it to run
Travis
EricW 10-16-2012 10:29 AM
Travis
That depends on the motor and ESC, you need to provide more details about both.
dtr 10-16-2012 11:04 AM
Almost all lrp speedos can work only with a sensor cable.
klaymon 10-16-2012 11:06 AM
Even if it does work without it, it's a $6 part at your LHS. Get one and know the system is complete.
The Captain 10-18-2012 06:56 PM
You can run any sensored motor sensorless or sensored, but only some escs can do both. Consult the esc manual.
