Lipo battery balance lead broke off >
Old 10-14-2012, 07:47 PM
Default Lipo battery balance lead broke off
Hey guys,
When I bought my truck used it came with a venom lipo battery and the center wire lead broke off in the hole. I tried using a magnet to get it out but that did not work.
Can I do anything to save my battery?
Thanks,
Kevin
Attached Thumbnails Lipo battery balance lead broke off-img-20121014-00306.jpg   Lipo battery balance lead broke off-img-20121014-00307.jpg
sly1types is offline
Old 10-14-2012, 08:01 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
they push in pretty good a magnet isn't going to pull it out. I can't see anything in hole in your pics, are you sure it's in there??
racer1812 is offline
Old 10-14-2012, 08:03 PM
Ya I'm positive its in there.
Old 10-14-2012, 08:07 PM
Super Moderator
racer1812's Avatar
Try putting in a plug and hope it goes in far enough to hold and make good contact. Other than that...not sure
try putting in the plug and take a pic of that, would give a better idea how far down it's broke off.
Old 10-14-2012, 09:04 PM
If you can get a pair of cutters or something thin under the lead hole, you may be able to pull the socket up out of the housing and press the broken lead out from the wire side.
Though if you can do that, you can also just replace the socket, or cut into the housing and direct wire everything.
WindDrake is offline
Old 10-14-2012, 09:26 PM
The Captain's Avatar
Happened to me before, I used an xacto knife and got it out no problem.
The Captain is offline
Old 10-14-2012, 09:30 PM
Can you elaborate?
Old 10-14-2012, 10:30 PM
Moderator
badaml's Avatar
Trader Rating: 127 (100%+)
You could get another lead or something similar, and put a small amount of ca on it. Then push it down, wait a few minutes, then pull it out with the broken tip attached from the glue. Use a VERY small amount though, as you don't want to glue the broken piece in the hole.
badaml is offline
Old 10-15-2012, 09:34 AM
Super Moderator
racer1812's Avatar
Or split the case giving access to the plug and like said above, push it out from the bottom side of the plug.
Old 10-15-2012, 10:57 AM
mkiiina's Avatar
Trader Rating: 69 (100%+)
maybe a dental pick. Ive used them with good results previously.
mkiiina is offline
Old 10-15-2012, 11:46 AM
Trader Rating: 41 (100%+)
I would go with Racer's idea, but instead of splitting the case, just drill a tiny hole on the bottom of the case and push your bullet up from the bottom with a piece of piano wire. Seal it with a piece of tape or some shoe goo when you're done.
Ropes is offline
Old 10-15-2012, 06:16 PM
Stick xacto blade between small gap and pry it out.
Old 10-15-2012, 07:08 PM
Tracy B's Avatar
I like this idea.
Tracy B is offline
