-   -   help- Hobbywing 9T 35A esc (https://www.rctech.net/forum/radio-electronics/669496-help-hobbywing-9t-35a-esc.html)
bj-99 10-12-2012 01:53 PM
Hi Guys,
New HW Brushless Motor Combo 9T + 35A v2 ESC. On Lipo battery no apparent problem. On NIHM, car runs 30 second at full speed, after that it will accelerate to about 1/2 speed max for about 25 yds, then will accelerate to full speed for 25 yds. it will repeat this when I stop & re accelerate, continually.
ESC is set to factory defaults.:(
klaymon 10-12-2012 01:55 PM
Check the paperwork/instructions to see if that ESC has a LiPo cutoff setting that you can turn off/on. If it does, you cannot run NiMH with the LiPo cutoff turned on. If you are running NiMH just disable the cutoff, but remember to turn it back on when running LiPo. It's a safeguard to keep from running your expensive and volatile LiPos to a dangerously low level.
bj-99 10-12-2012 02:02 PM
HW issue
Really? I asked that same question in a Redcat forum & was told that I could leave the cut off set for Lipo & still run MIHMs. I will try that later today. thx.
& yes Lipo cut off is turned on.
headbasher 10-12-2012 08:58 PM
Yeah, the NIMH batts voltage will dip down to the cut off under load. The lipos maintain more of a level voltage.
bj-99 10-13-2012 01:15 PM
great answer.
Klaymon- Thanks a lot. that did work fine.
klaymon 10-13-2012 01:38 PM
Good deal.
