How to setup Futaba 4PL with Losi 22 buggy 1/10 >
Old 10-04-2012, 01:12 PM
Default How to setup Futaba 4PL with Losi 22 buggy 1/10
Hello everybody i have another amateur question.
Ok here is what i want to know because i am so confused and i dont know how to setup my new losi 22 buggy 1/10 and make it work with my radio Futaba 4PL
OK so i instaled new receiver for my futaba controller everything is working fine but i dont know how to disable reverse and is that really necessary ?
All i know nobody is using reverse and i dont even know why heh.
So 2 things do i need reverse if not why ?
And how can i disable reverse ? i want my car only break .
Thank you everybody
roman76 is offline
Old 10-04-2012, 01:53 PM
MarkA's Avatar
Trader Rating: 21 (100%+)
People disable reverse because using it during a race is not allowed - you have to wait for the marshal to get you re-set.
Reverse is disabled through your ESC's settings, not your radio. What kind of ESC do you have?
MarkA is offline
Old 10-04-2012, 02:16 PM
Thanks for the fast answer.
Well ESC is ROAR-legal sensored system thats what i red on losi web site
i have exactly Losi 1/10 22 2WD Brushless Ready to run Buggy,i hope that helps.
And btw how can you program ESC and what you can program in ESC ?
Thanks again
roman76 is offline
Old 10-04-2012, 02:29 PM
MarkA's Avatar
Page 6 of the manual will tell you everything you need to know about your ESC.
MarkA is offline
Old 10-04-2012, 03:48 PM
Thanks alot !!
roman76 is offline
Old 10-04-2012, 04:44 PM
Trying to calibrate my transmiter but it doesnt work ESC Programming works just fine without any problems but after calibration my car doesnt work i hit throttle and car is not responding
roman76 is offline
Old 10-04-2012, 05:07 PM
Here is what i suppose to do ok !
One-Touch Calibration
The motor does not receive power when the ESC is in programming
or calibration mode.
1. Power the transmitter on.
2. Press and hold the Setup button while powering the ESC on.
3. Release the Setup Button when the Green LED is on.
4. Move the throttle to the full throttle position. Hold full throttle until
the Green LED glows solid, confirming the forward endpoint position.
5. Move the throttle to the full brake position. Hold full brake until the
Red LED glows solid, confirming the brake/reverse endpoint position.
6. Return the throttle to the center/neutral position. The calibration
is complete when both Green and Red LEDs glow solid.
everything is fine but if i do #4 and holding full throttle until
the Green LED glows solid nothing happen after i release the throttle green LED glows solid YES but i cant do #5 because if i move the throttle to the full brake position there is still solid Green until i hit full throttle again then red LED start flashing but become solid Red after like 3 or 5 sec and i am not touching anything.
I have no idea what to do now
roman76 is offline
Old 10-04-2012, 05:29 PM
Ok i changed receiver for different transmitter that was in RTR box and calibration works perfect !!!! but with my futaba 4pl transimtter for some reason break doesnt work actually it does nothing and when i calibrate full throttle the green led stays solid and nothing else so i am pretty sure i have to do something with my transmitter but i have no idea what
roman76 is offline
Old 10-04-2012, 07:36 PM
nitro_mt_racer's Avatar
Trader Rating: 232 (100%+)
Is your throttle channel "rev" or "norm" on the radio? Futaba generally has to be reversed to function correctly.
nitro_mt_racer is offline
Old 10-04-2012, 08:59 PM
You are right when i set Rev it works but now there is another problem on 70f30b my break doesnt work but 50f50b breaks work just fine
roman76 is offline
Old 10-04-2012, 09:13 PM
MarkA's Avatar
Make sure your trim and subtrim are both at zero and your epa's are at 100 on the 4PL before starting the setup. Also make sure extra stuff like abs is off and so on.
MarkA is offline
