Ways to discharge lipos
Sometimes I do not use my fully charged lipos when I return home from the track. I have a good quality charger but it has no discharge feature.
What is a good safe and slow way to discharge my lipos with overheating or damage? What type of devise can I hook up to the battery which will discharge it? Thanks, Rick |
You can use a bulb discharger plugged into the main plug, along with a low voltage alarm plugged into to the balance adapter is a good way
http://www.onlybatterypacks.com/items.asp?db=13 |
Why would you wanna discharge lipos? it is better to leave them charged up.
im sending you a pm
i do not know if its right and fair to post up an outside forum link |
Originally Posted by pdxrc2838
(Post 11247986)
Originally Posted by EricW
(Post 11248135)
I've always read that storing a lipo fully charged is a bad idea.
i try to keep mine at the 3.8 range when im not using them
(Post 11247986)
SMC had a batch of cells that would puff when stored improperly. Running them in the car works well. I use my chargers that do have a storage/discharge feature, what charger are you using? |
DuraTrax 235
I was standing in my local auto parts store and looking for light bulbs for a discharge devise when the light bulb in my head went off.
I went home and built a board that has mounted on it, an old motor, ESC, receiver so that I can simulated a running car. I plug the battery in, turn on the juice and tape the throttle of my transmitter to about 1/4 speed and let her run. Comments on doing this |
If you have old esc's & motors, do the ESC's have lipo cut?
In the airplane world motors & esc's are inexpensive. My one plane with a 8x4 prop will pull near 27amps full load. Motor $10, ESC $15 Even 1/2 throtle would be plenty, but without a load there won't be much amp draw. Most ESC's will usually cut near 3.2 to 3.0v per cell, unless it is adjustable. |
| All times are GMT -7. It is currently 10:02 PM. |
