-   -   pro tek lif battery (https://www.rctech.net/forum/radio-electronics/662037-pro-tek-lif-battery.html)
JHN1 09-14-2012 01:51 PM
pro tek lif battery
hello
Hope i can explain this the right way. So i just purchased the protek life reciver battery and also purchased the ko pro 2 switch and put everything together. The problem i am having is that when the battery is fully charged and i go to plug it in on the switch it only shows full green for just couple of minutes and then it drops 2 green bars right away. But when i put a regular nmh battery it shows the full green. I cant tell if i am doing something wrong or is this normal.
Any help would be great
thanks
john
lewis110 09-14-2012 03:41 PM
Maybe because a life battery is 6.6 and a nimh is 7.2?
JHN1 09-14-2012 03:51 PM
Possible but its starts off with full green lights and within minutes it drops down to 1 green light.
thanks for the reply
cr133r 09-14-2012 04:33 PM
Its likely just barely passing the threshold for the full green lights and as soon as you use it slightly the voltage drops below the threshold. I wouldn't worry about it and just use the rest of the lights to determine state of the battery.
