Help! Receiver vs module
Can anyone help me clarify the difference between the receiver and the module?
Do you need both to run the radio? Thanks. |
Originally Posted by Wyumez
(Post 11198946)
Do you need both to run the radio? Thanks. A Module is a RF device that attaches to the radio transmitter to send the signals to the receiver. Not all radios require a module because many if not most have the module built in. You only need a module if your radio requires one example: Futaba 3PK/PKS, Airtronics M8/M11, etc. And yes if your radio needs a module then you need both a module and a matching band receiver, i.e.; 75MHz FM, 27MHz FM, 75 MHz PCM, 75 MHz HRS, 2.4 GHz DSM, etc. These are examples of bands. |
| All times are GMT -7. It is currently 04:48 AM. |
