Revtech 17.5t Motor Help!
Is my timing set to 0? I'm running it on a tekin rs, and It looks like it's running faster than a 17.5t should... I had it on blinky earlier, but I am almost sure it back to default
http://i1127.photobucket.com/albums/...E0DFB5D772.jpg |
I'm not sure but every blinky stock class I've ran in motor timing is allowed.
The zero timing for the motor is the middle line. The motor has around 30 degrees of built in timing. The problem is probably with your speedo not being set to blinky mode. Check it with a Hotwire to make sure. Lights 345, or 35 should flash depending on your software
Looks right now like your at negative timing Also a revtech will run faster then most Not sure why or how but they run fast .i always run about 3 bars past center but it looks like its in a buggy max the thing positive And really watch it fly also watch temps
Run no mare than 2nd Mark from middle mark and gear to temp also 12.5 ht rotor helps a lot for offroad that is def.neg timming this is what billy Bruce from trinity told me depending on your track less timming and more gearing may be better
| All times are GMT -7. It is currently 12:57 PM. |
