flysky gt3c saving problem
hi guy,
I have a gt3c for my wraith and for some reason, when I try to set the channel 2 to reverse, it won't save. It will stay correct until I power it off, then the setting return to default normal. The weirdess is that my channel 1 is reverse too and it stay that way. Anywone know what's wrong with that??? thanks |
Have you pressed the enter button after you select your setting?
for some reason, that was the solution. I was pretty sure that I have try it this way but it appear that I don't...
thank you for this simple but working solution :) |
| All times are GMT -7. It is currently 02:02 PM. |
