mod timing
Hey everyone. I use to run a 17.5 non ramping class but, track has decided to run modified. Honestly I am clueless. Is there a thread around that explains the difference? My current gear right now is Team Orion R10 w/ 13.5 pro race, Orion servo, Reedy shorty lipo and it's installed on my Tamiya TA06. I appreciate everyones opinions thanks.
Semper Fi |
What's the question being asked? About can timing?
Defensor Fortis ;) |
Originally Posted by So*Cal AFDude
(Post 11133555)
For ESC timing I would go up two timing increments (if you don't use the programer they go up in set ammounts last I checked) every time, check temps and if it's too hot, go down one increment. This way you'll cover more ground faster. I believe you can also set a timing "turbo boost" that kicks in at wot, but I've heard that it's not very smooth.
Originally Posted by Racer X8000
(Post 11134289)
Most the time none is going to be plenty. But adding a little can smooth out the power band.
| All times are GMT -7. It is currently 11:10 PM. |
