-   -   KO RSX and Voltage Regulators (https://www.rctech.net/forum/radio-electronics/656135-ko-rsx-voltage-regulators.html)
DaveG28 08-22-2012 07:55 AM
Has anyone used a lipo voltage regulator when using the RSX servo's?
If so did you have any brown out problems etc? It's just I am aware most regulators seem to be 5A limited (similar to most 8th esc's in 8E buggy) and I am not sure they can handle the servo's...as most esc's cannot!
Dave
Frank L 08-23-2012 07:29 AM
Dave
I run a rsx servo in my E buggy with a rx8 without issues. Why would you use a voltage regulator on an E car?
Tim3 08-23-2012 08:22 AM
I am using one too. Don't use voltage regulator, no need. power from the esc will be enough or straight to a two cell lipo. If your already having brown out problems get a cap. spektrum rx's can't run on low volts.
