-   -   Dynamite Lipo Glow Driver (https://www.rctech.net/forum/radio-electronics/654822-dynamite-lipo-glow-driver.html)
aznitronut 08-16-2012 10:00 PM
Has anyone had problems battery dying fast? What is the Voltage supposed to be when full charge has been done? Is 4.3 volts bad or good at tip when full charged? Is the charger that comes with glow driver screwed up if glow driver tip is showing 4.3 volts when charged? Is it supposed to have 1.5 volts at tip will full charge?
Integra 08-17-2012 09:10 AM
Pretty sure its a Single 1C so Voltage Should be where your reading it, There will be a Step Down module of sorts that I would assume would back the voltage down to keep our Plugs alive.....Ive been running my lipo ignitor for at least a year now with Zero issues. Now that's not to say a few local's haven't had any problem's But i sure haven't. :nod:
aznitronut 08-17-2012 10:03 AM
This is the 4th one I have had, take a volt meter, if you have one, put negative probe on the outside, chrome part, positive probe inside, like you are trying to attach it to a glow plug, see what the voltage is, post that if you can. I haven't been able to contact Horizon, there phone system must have been down yesterday, busy signal for 5 hours straight.
aznitronut 08-17-2012 10:04 AM
By the way, it is a 1C, thanks Nick.
