Lipo, do i fix?
I have a 3s Zippy soft case that has about 20 cycles on it. The other day it quit working like it had an open circuit some place. I test at the plug with my DVM and it shows 11.6V but will fluctuate to 8.8 when the board is pressed or moved around. None of the cells looked damaged and none are swelled.
When i plug in to the esc it does nothing. When plugged into 2 different chargers one shows over voltage and the other shows open.. Actually i did 3 chargers, mine showed bad balancer connection. My questions if whether it is safe to pull all the solder off the tabs and wires and re-do that work. I am more than comfortable soldering but i was told by the LHS to recycle it. They were concerned with an open spots in any of the cells causing a fire while working on it. If i do resolder it all, can the board touch the alum casing on the lipos? |
My general advice is to not try to work on lipo packs; doubly so for a fairly cheap soft-case where the chances of there being something additionally wrong internally are going to be greater.
Originally Posted by MarkA
(Post 11023548)
I would say the same thing. I have seen people take out dead cells and stuff, but random troubleshooting seems risky. I have a venom 3s for my merv that has one cell that gave out, but I dont want to take it out. I am good at soldering, but you never know. The iron or gun could slip or something and then you have a lipo fire. With such a cheap pack, I would just recycle it and buy a new one. |
i will head all of your advise... time to figure out if i want to go 5s pack or another 3s....
| All times are GMT -7. It is currently 04:25 AM. |
