Hitec 7955 with Racers Edge servo horn >
Old 07-17-2012, 07:44 AM
ironzgti35's Avatar
Trader Rating: 33 (100%+)
Default Hitec 7955 with Racers Edge servo horn
Anyone running this combo? Went to throw it together and the servo horn binds on the servo case when tightened down, almost as if the horn is too tall. 2 options came to mind - 1) shave the case down near the splines in order for the horn to seat fully without rubbing, or 2) just use the 2 small clamping screws to hold the horn on and forget the center main screw
ironzgti35 is offline
Old 07-17-2012, 08:26 AM
Tran901's Avatar
Trader Rating: 95 (100%+)
Dumb question. Are u using the right servo horn? Right tooth and off-road/ on-road arm?
Tran901 is offline
Old 07-17-2012, 08:53 AM
ironzgti35's Avatar
Fair question, ha. Using this servo horn, spline count is good, just too "tall" if you will.
http://www.amainhobbies.com/product_...-Hard-Anodized
Old 07-17-2012, 11:06 AM
trickedout's Avatar
Trader Rating: 31 (100%+)
why not just find a few small shims and put inside the horn to raise it off the case.
trickedout is offline
Old 07-17-2012, 11:52 AM
I used that combo in my rock crawler for about two years, never had an issue. Perhaps it was just a machining variance, you can file down the servo horn, it's cheaper than replacing the cases.
AreCee is offline
Old 07-17-2012, 11:55 AM
ironzgti35's Avatar
There's another option. I'll see what I have around the bench tonight. I have to imagine its just a variance in machining process
