Turnigy TrackStar Motors
#601
I believe so. They are very different in design and performance. I have been running the 13.5t and 17.5t motors and they are just a fast as any racer at a very competitive track that I frequent.
I have never been able to get the v1 motors even close in performance. (poor RPM output)
I believe the V2 motors are of a short stack design with hi torque rotors so they have nice grunt and RPM. For $50 it the best motor I have ever run. It easily competes with my $170 Fantom D4 for 1/3rd the cost.
So far I have had zero problems with any of the (4) V2 motors I have purchased.
I'm a happy camper!
I'm a happy camper!
#602
I'm a happy camper!
I'm a happy camper!
#604
#605
Did anyone get one of the new V2 motors and notice the end bell and motor body screws to be really soft, and/or broken right out of the box? I noticed 1 of 3 end bell screws had it's hex head popped off from the factory, but luckily I was able to remove the shaft of the screw. I also noticed the 3 long screws seemed to be made from a really soft alloy.
I'm assuming these will need to be replaced if you take your motor apart a few times for cleaning etc.
I haven't had a chance to test my V2 21.5 motor out yet, but if it's anything like the V1 motors I've seen on the track, it should be a performer.
#606
Please post your comparison of the v2 21.5 vs the older motor. Will it be a good motor for f1?
#607
#610
R/C Tech Elite Member
YES I had that took a picture of the broken screw and the motor was warrantied. Still need to work out what screws would be a direct replacement but the endbell it screws into is plastic and I can see those flogging out in time.
#611
Had the same thing happen to me, it is covered under warranty but the manufacturers are sending out replacement screws to everyone who bought them, eventually. In the meantime I am going to test the titanium 2.5mm screws at HobbyKing, they won't snap. As a temporary patch I am using a M2.5x5mm cap, it does the job fine.
#612
