-   -   mmp punch control (https://www.rctech.net/forum/radio-electronics/645669-mmp-punch-control.html)
68sportcoup 07-13-2012 09:51 PM
mmp punch control
so after frying my sv2 i bought a mmp and ran it tonight for the first time.
after updating the software had to revert to the older software.
it seems like it has some punch control that i cant remove.
from a dead stop nail the throttle and it takes a second and roles a little before it realy spools up before it.
reverting to the older softer helped but is there any other fix anyone knows about my motor is 1410 3800.
Mike
crusey_aus 07-14-2012 12:35 AM
Is the ESC calibrated to your transmitter ?
What batteries are you using ?
Cheers
TOM MAR 07-14-2012 02:08 AM
Did you reset to high power starts ? Certain updates reset defaults.
68sportcoup 07-14-2012 04:08 AM
high power starts il have to check that .
the batts are turnigy 2s 6000.
it just seems different than it was with the sv2.
TOM MAR 07-14-2012 11:10 PM
Yes that is a must:tire:
68sportcoup 07-15-2012 07:03 PM
just got home from camp and checked it out high power starts was on high.
so i then reverted to one from the oldest firmware.
and it works great now.
i dont know why the firmware needs to go back to that old but it worked.
TOM MAR 07-16-2012 07:08 PM
Ya know, i should have thought of that. I have 3, 1 cell MMP's & I learned a long time ago that sometimes the programming can get corrupted several different ways.
Like you I use an older firmware (1.29) because I run faster lap times with it. One problem castle has had with their firmware is flash corruption upon disconnection from the computer.
Here is a link to the fixes their firmware updates are supposed to do.
http://www.castlecreations.com/downloads/frh-mamba.html
Mine have also corrupted from time to time when reducing timing & or rpm ranges.
68sportcoup 07-21-2012 12:04 PM
esc seems to be working ok know but all i can say is i think the sv2 i had was better.
never a question about what it was doing it just worked.
i may try one of those brushless hobbies esc's it looks pretty good for 1/2 the price kinda wish i just bought that.
so how do i do the update when i used the upodated version it had a bunch of lag of the line.
Grasschopper 07-21-2012 07:53 PM
I have two of the BH 120A ESCs and they are quite good, in all honesty I like the Castle programming software better but the shitty BECs in the Castle ESCs keep me from buying them. The BEC in the BH ESC is nice and strong.
