-   -   Help with Motor Issue (https://www.rctech.net/forum/radio-electronics/644375-help-motor-issue.html)
Wildcat1971 07-09-2012 11:32 AM
I am trying to trouble shoot a motor issue I am having.
Motor: Reedy Sonic 7.5
Issue: Wont work with the sensor cable plugged in. But will work without the cable plugged in. I tried 4 different sensor cable, same issue. The esc runs other motors fine sensored.
My first guess is that the sensor board is shot. I was running the motor around 160 deg and when it died it was only 140.
The Captain 07-09-2012 01:37 PM
Probably the hall sensors. Replace the board
http://www.teamassociated.com/reedy/parts/details/959/
Wildcat1971 07-09-2012 01:45 PM
what are the causes for the board to fail? I would like to prevent/reduce this from happening again.
The Captain 07-09-2012 01:54 PM
The sensors can fail for a number of reasons, and there isnt really much you can do about it unfortunately. Luckily they are cheap enough to keep some spares around.
