The new 8000mah Dual Core LiPos from MaxAmps.com
Hey guys,
Here is a thread to discuss our new packs, the 8000mah Dual Core Lipos. Hope you guys like this new release. Thanks - Brandon
These packs are a tight fit but will fit in most 1/10-scale trays.
Some info on these new packs:
• 50+mph in most brushless setups (7.4 volts)
• True 150C rating
• 48 minutes average run time (8000mah capacity)
• Lifetime Warranty
• 5C fast charge capable
• 100% waterproof
• Built today with factory fresh cells
• Built with genuine 12awg Deans Ultra wire
• We add the connectors and balancing taps for you
• 137mm x 45mm x 33mm, 441g
More information can be found here:
http://www.maxamps.com/products.php?cat=329
• True 150C rating
• Lifetime Warranty
• 100% waterproof
if going on a scte losi you will need to purchase the velcro battery straps for the xray which is 300 mm in length!
Wow... You relabeled all of your current packs and charrged more.
FYI a 2s2p config is not desirable. If one cell is a little 'off' the pack blows up.
We did not relabel any current pack. And please do not give out any false information on the packs without trying them first. These are very safe packs and we stand behind them with a lifetime warranty. On the bench and in real-world testing these packs are very good and offer an insane amount of power.
Hoo-Boy, I got dizzy from the high price of $150 for a 7.4V pack.
Wow, does it drive the car for you too?
Problem is that 8A is a lot for a racer who uses maybe 1.2A or so in a 6 minute heat but I can see where the extra weight could be used as ballast to keep the car from going too fast.
Super Moderator
Trader Rating: 31 (100%+)
Millions of people pay hard earned money for bottled water everyday too. Who cares?
You can balance charge at 40 amps.. Nice!!
You accuse me of providing false information, would you care to talk about your 'C' ratings?
You have yet to provide ANY discharge graphs of your packs...
Well, my friends dad had a 5.5t hobbywing motor in his stampede and had 19/90 gearing and it was going about 40-45 on 2s. If he changed the gearing a bit it would get above 50. BUT it ran HOT.
I recently discovered why my blitz was so under powered and fixed the issue. Now I got 40.5mph on 2s with stock tires and 27/83 and the motor is still always under 130 degrees. I have a lot of room to change the gearing there. Most of the time I get the motor around 110 to 115.
But that isnt what this thread is about, it is about max amps new battery.
I agree with the post above, their C ratings are total bogus and even racers dont need anything that high. A good 60c or maybe a bit higher, is good for most racers. Plus these are soft case from what I know and they are still hard to fit into a truck unless you use a velcro system.
Correct me if I am wrong, but dont 2s2p packs normally have a higher internal resistance?
Should be equal if similar quality cells were used
Cell resistance decreases with capacity and is halved when connected in parallel
Values plucked from the sky below but you will get the drift .........
8000 mah cell = 2 milliohms
4000 mah cell = 4 milliohms
2 x 4000 mah cells in parallel = 8000 mah and 2 milliohms
Not that it is even possible but I would guess a 75c rated 8000 mah cell would need to be under 0.2 milliohms
Hazard a guess at what these ones are ?
Cheers
