tekin sc 4x werid noise >
Old 06-19-2012, 11:39 PM
meon99's Avatar
Trader Rating: 77 (100%+)
Default tekin sc 4x werid noise
I bought a brand new losi SCTE and the MMP. I installed everything properly with the KO servo with the external BEC, everything runs good. however, everytime when i full throttle from zero, i heard weird noise from the motor. Then I removed the motor and trying to hold the pinion on the motor and apply throttle. it is where the problem is. the motor generate a little to loud noise when i throttle up. i have tried different motors. this sc 4X is the only motor which will produce this kinda sound/ noise.
Please advise how to fix it.
Thank you.
meon99 is offline
Old 06-20-2012, 07:22 AM
Trader Rating: 21 (100%+)
Shim the diff
xxx123 is offline
Old 06-20-2012, 07:42 AM
Moderator
MarkA's Avatar
Of better, check the shims/play on the motor, especially if it's doing it when not in the truck. It could also be a cogging effect on that motor/esc combo that just won't ever go away.
MarkA is offline
Old 06-20-2012, 10:00 AM
meon99's Avatar
its not the truck, its the motor...... tired another motor on the truck, no sound.
I think i need to send it back to tekin to look at it.
meon99 is offline
