-   -   Transponder Questions (https://www.rctech.net/forum/radio-electronics/633181-transponder-questions.html)
slowmotion36 05-30-2012 12:29 PM
I'm new to rc racing and in the process of building my car. I purchased a Spektrum DX2E Radio which comes with an SR200 receiver. The receiver only has 2 channels. Steering, throttle, and a spot for the bind plug. If I purchase a transponder where do I plug it in. Would it just go into the bnd slot. Or is this setup not suitable?
AreCee 05-30-2012 01:36 PM
It can go into the Bind/Battery slot and have no effect on the other two channels since it's not connecting to the signal phase but only the positive and negative power leads.
slowmotion36 05-30-2012 02:32 PM
Good to know. Thank you
brenman 06-01-2012 09:19 PM
O. K. I'm a newb
What is a transponder and what is it for?
CruiseM 06-02-2012 12:47 AM
The term is a portmanteau for Transmitter-responder.
It is needed for Lap timing.
The link goes to the most common used System in RC.
http://www.mylaps.com/index.php/emea...es/B2C/rc/home
Cruise
Dave H 06-03-2012 11:34 AM
It’s for lap counting when racing. Each RC has a transponder that signals the track’s lap counter and timing software program for each lap.
Older transponders were “house” transponders that the track supplied and the racers shared. Most now use a “personal” transponder (aka PT) that the racer buys and leaves in the RC, makes the race program run much smoother. Like the MyLaps Cruise linked to.
