-   -   DX3S Range??? (https://www.rctech.net/forum/radio-electronics/630997-dx3s-range.html)
Sc101 05-23-2012 05:21 AM
DX3S Range???
I just bought a used DX3S and a SR3000 receiver. I am having a few issues right off the bat getting this thing to work.
1. I have no reverse most of the time. It will work once in a great while for no apparent reason but, most of the time it does not work.
2. The range is terrible. I would say maybe 25 to 30 yds it cuts out. I have to walk almost right up to the car to get it to connect again. I did rebind it a few times but to no avail.
Just so you know I am a complete noob to RC and spektrum TX/RX so it could be I have set something up wrong. I have this on a sc10 and I never even put the body on while testing. The sr3000 has a 3-4 inch antenna straw on it and maybe another couple of inches of antenna. Thanks for any help getting this running.
Devigili22 05-23-2012 06:12 AM
Twist any wires carrying any current. This is known to help block interference you might be getting.
Sc101 05-23-2012 06:35 AM
Twist the receiver antenna wire? Or tx wires?
weight 05-24-2012 01:31 AM
Its obviously not working properly send it back.
I can get 200m+ with DX3e and SR300 before it starts to glitch with the antenna wire exposed. No reason you cant get the same if not more. Search youtube 'Spektrum DX3E Range' to see my setup on a Hyper 7.
Devigili22 05-24-2012 05:52 AM
None of those, wires like your motor wires that connect the motor to the ESC.
T Tom 05-24-2012 05:57 AM
Thats why I moved on from spectrum.
Sc101 05-24-2012 04:11 PM
I
Turns out the receiver was not good. I bought a sr300 new and the range is fine but I still have no reverse. Is there some sort of calibration with the esc? Like I said before reverse will work for like a couple of seconds then nothing.
crusey_aus 05-24-2012 04:34 PM
ESC needs to be calibrated to your transmitter, read your ESC manual
Cheers
Sc101 05-24-2012 08:16 PM
Cheers
Works great now thanks:nod:
