-   -   HITECH 4X AC PLUS CHARGER (https://www.rctech.net/forum/radio-electronics/630140-hitech-4x-ac-plus-charger.html)
JHN1 05-20-2012 03:02 PM
I just bought myself the hitech x4 acplus charger and went to charge and discharge a life battery and when i discharge the fan keeps going on and off
is this normal?
thanks
john
Grasschopper 05-20-2012 05:32 PM
is this normal?
thanks
john
I don't have one yet (plan on getting one) but my guess is that it is totally normal. The fan will be thermally controlled turning on when the system gets to a certain temp and then off again when it goes below some temp. When discharging a battery the system will generate a lot of heat and kick the fan on.
tdt1805 05-20-2012 05:47 PM
Im not knocking this charger but why is everyone in love with this charger? There are better chargers out there for 200 dollars IMO.
Grasschopper 05-20-2012 05:56 PM
I was liking it for all of the features. The charge discharge cycle plus can charge 4 batteries at once...honestly I'm just getting back into this, are there other chargers with the same feature set?
tdt1805 05-20-2012 06:22 PM
powerlab 6. Can charge 6 batteries and do everything else plus is the only charger I have seen bring ball a dead cell. Really any fma/revolectrix charger would be better.
sleek 05-20-2012 06:57 PM
yes the fan does go off and on frequently and more so with bigger cell count batteries, will even stay on for long periods at a time
LasagnaCat 05-20-2012 06:58 PM
Better is a matter of perspective. For those of us with wives, girlfriends, and/or kids that go the Hitec is awesome. "You use the two on the left for your packs, let me do everything else on the right side." Just makes things simpler. My other half would never be able to manage more than one pack with the FMA, she's comfortable with the Hitec. I dragged $$$ chargers and power supplies back and forth to and from the track since the days of the original Turbocharger, and really the Hitec does just about everything I need now in one unit - my old power supply cost almost as much new as this charger, and that's long since been sold. Being the most capable or most technical option doesn't always make something the best option.
Yes, there are more expensive units out there... and chargers with more features... this is a bang for the buck situation, for us at least. I do still have a "better" Hyperion charger sitting here as a bench charger, which has been sitting untouched since I bought the Hitec. :)
The only disclaimer I have is that we ONLY run 2s lipo packs (and one 3s tx pack,) which is right in this chargers wheelhouse. If I ever ran higher cell count packs, I'd possibly go another route.
PlayingDirty 05-25-2012 11:08 AM
is this normal?
thanks
john
Mine does the same thing.
retsoorkcuf 05-26-2012 10:01 PM
balance charge mode
in balance charge mode can i charge with the same amp rating 6amp that i use in regular charge mode .
dtr 05-27-2012 12:48 AM
Yes. Only at the end in the balancing phase the current will drop to a few hundred milliamps.
