Receiver Question
Hey guys,
I have a Futaba 4PL radio with 2 R210GF receivers. I just picked up a 3rd car and don't have a 3rd receiver yet. Is it possible to pull one of my receivers from one of my other cars and set it to a new model on my radio so I don't have to switch all the settings I have programmed for the first car? I'd basically be using one receiver for two different cars with different settings for each car. Will this work or not? I should add I intend to get another receiver but was just wondering if I could do this for the time being? |
Yes it should work for ya.
I know that with my Airtronics tx/rx, it isn't specifically binding the channel/ model # on the transmitter with a specific receiver, it is just binding the receiver to the transmitter in general. therefore, this allows you to use the receiver with multiple cars, and as you suggested, just create a channel on the transmitter for each car. Just make sure you only have one vehicle turned on at a time otherwise you will be driving more than one vehicle (i've done that before!!) |
I think plane/heli radios are specific model to rx (on some futaba and airtronics models, but mostly the higher end ones), and spectrum is specific model to rx.
I dont belive Futaba does this with there surface radio's though |
Yes it will work without any problem.
The FHSS receiver only binds to the radio and not the model designation. In other words you can set any number of models and use the same receiver in each one without resetting anything. |
Thanks so much for the help everyone!
servo transmitter receiver problems
i have a Acme nb16 nitro car and had to replace the receiver box 27mhz and steering servo but the problem i've got is that the throttle servo works but not the steering servo. i was wondering if the crystals are faulty?? any help regarding this issuse would be really great
Originally Posted by sidjames73
(Post 10744101)
arecee i just tried that but still dont work. would it be that the new servo is faulty as i also tried the throttle servo in the steering channel on the receiver and that servo works by steering and throttle controls
I think you may have answered your own question.
| All times are GMT -7. It is currently 10:28 AM. |
