-   -   Blinky balancer instead of charger balancer? (https://www.rctech.net/forum/radio-electronics/627072-blinky-balancer-instead-charger-balancer.html)
brothainchrist0 05-09-2012 12:43 PM
Hey guys, I am buying a charger that has the 5 white balance plugs on the side of it but I would rather use the AstroFlight Blinky balancer. Is it possible to use that charger with the Blinky Balancer? It's the Onyx 235. I just don't know how the charger will know then when to stop charging if the balancer isn't internal. Thanks for the help guys!
Kyle
dethklok151 05-09-2012 07:36 PM
The charger will stop when it detects total voltage at 8.4. I have been using a blinky for a couple years just fine.You just dont get a readout of actual voltage. Make sure to get the right blinky. They make one for lipo and one for li-fe . Dont ask how i learned this.Also some chargers internal balancers operate at a different amp rate so they might balance faster than your blinky will.
brothainchrist0 05-09-2012 10:02 PM
excellent. that's exactly what i wanted to hear. thanks much!
acuratech 05-13-2012 10:45 PM
does anyone have any exp with the deturm dc6 charger ?
I have 2 and only getting like 2800 MAH on a charge and that was after a discharge @ 3 amps on a balance charge
