ESC/Motor Question...
So will a 35 amp EZ run esc, work with a Tacon 4300Kv/9T motor? will the esc be able to handle it? note it has a cooling fan and capacitators.
What car ?
What speed do you plan to gear it for ? Cheers |
Originally Posted by crusey_aus
(Post 10638160)
What car ?
Yes, the 35A is ideal for the 2848 Tacon motors.
Originally Posted by burnineyes
(Post 10639206)
And I am sure you know this, but I just read your signature and thought I should stress the issue. This is a budget system and it could melt if you attempt to set a land speed record with it, but should be perfect for a track or driveway.
(Post 10640831)
I am running the 8.5T with a 60 amp ez run esc and it works fine and has loads of speed :lol:, also the new system that im having questions about is for a rock racer/crawler. should be loads of fun.:nod: |
| All times are GMT -7. It is currently 05:04 AM. |
