Need Futaba 3PJ programming help
Hello, I have a Futaba 3PJ transmitter and a Futaba 3 channel FP-R113F receiver.
My problem is that I'm trying to run a Futaba S3004 servo on channel 3 and I can't get the servo to "sit still" in the middle and I need advise on how to program some "deadband" or whatever it's called on channel 3. Moving the channel 3 knob just one click either way on the detent moves the servo and I need some dead space between right and left. Any help is appreciated! Thanks, Darwin |
Channel 3 ATV must be set to 100% for both up and down, this should give you left, center, and right positions. If it doesn't move like it should check channel mixing to see if it gives you more range or maybe it's limiting travel. Best bet is to reset that model memory and make sure 3rd ch ATV is set to max 100%
Futaba 3pj channel 3 programming needed
Originally Posted by Steve.
(Post 10631416)
Rather than using the knob, try programming DT3 for your 3rd channel... I think you'll have better luck as it will act like a three position switch.
| All times are GMT -7. It is currently 11:49 PM. |
