Flux Blur ESC Issue...HELP!!
So I would be calling HPI with this issue, but they seem to be closed today. I just received a brand new Flux Blur ESC as a replacement for a bad part on a used Vorza. I plugged my LiPo in and all seemed to be working fine for a few minutes. Then all of a sudden it acts as though my batteries have no juice, like the cutoff is going into effect. However, after checking, this is not the case. I checked the ESC and there is a orange and green blinking light at this point. Also the auto LiPo is not working properly. Example: I plugged in 2 brand new 3S Gens Ace LiPo's and it only recognized 4, then 3...I am going insane trying to get this thing working. FYI - I have the castle link and have setup the ESC properly. Any help would be greatly appreciated!
What ESC settings are you using ?
Have you calibrated the ESC to your transmitter ? Cheers |
Originally Posted by crusey_aus
(Post 10580144)
Have you calibrated the ESC to your transmitter ? Cheers I have calibrated 3 times, each time after settings were changed. I will get back with results on a freshly charged batt, and default settings. |
Use the following settings to get you started
Auto-lipo LVC 3.5v / cell Zero timing (0) Start Power High Punch and Torque Limiting disabled Centre your throttle trim Set your throttle / brake EPA's at 100% Calibrate the ESC to your transmitter Cheers |
| All times are GMT -7. It is currently 03:30 PM. |
