-   -   Brushless motor? (https://www.rctech.net/forum/radio-electronics/616910-brushless-motor.html)
fisch83 04-08-2012 09:04 AM
Brushless motor?
I'm running a venom brushless motor/esc and the last time I had the truck out it seemed to be down on power. Is there any way like with a meter I can test the motor to see if its good or starting to go bad? Thanks.
rc10t3b4 04-08-2012 09:56 AM
sounds like the battery.
fisch83 04-08-2012 12:40 PM
I did make a couple of different runs with different batteries. I run 2s lipos and there not that old so they shouldnt be causing any problems. I have since put on a new connector but havent had a chance to run it yet I'm not sure if that coulda been it or not?
Paul Susbauer 04-13-2012 09:27 AM
Your batteries, if they are LiPOs and they were stored over the winter, could be simply losing their punch.
LiPO's as they age, increase internal resistance, which effectively decreases the C-rate. When they are stored fully charge, this is
If you store your LiPOs at around 3.75-3.85 volts per cell, this is the best level to store your packs.
