sr300 glitch
Hey guys, I posted this once already but didn't see it so I'll post again.
MMP 1410 4Pole, savox 1256tg, sr300. Trying to center my servo and sr300 is glitching. I had the resolution set at 5.5ms and the receiver was blinking randomly as well as the motor would spool on its own. For troubleshooting I installed a non digital Hitec servo and bumped the resolution up to 16.5ms and everything was fine. What am I missing here? I don't think I should need a bec for one servo should I? any help would be greatly appreciated. Jay. |
Originally Posted by jayrat
(Post 10554772)
MMP 1410 4Pole, savox 1256tg, sr300. Trying to center my servo and sr300 is glitching. I had the resolution set at 5.5ms and the receiver was blinking randomly as well as the motor would spool on its own. For troubleshooting I installed a non digital Hitec servo and bumped the resolution up to 16.5ms and everything was fine. What am I missing here? I don't think I should need a bec for one servo should I? any help would be greatly appreciated. Jay. http://www.ebay.com/itm/ORANGE-RX-SP...item3370662734 |
Dont bother with a silly glitch buster cap
Fit an external bec and be done with it Cheers |
5.5ms isn't supported on DSM receivers like the SR300. Set it to 11ms or upgrade to a DSM2 receiver.
What's happening is that this servo is pulling more amps than the ESC can provide when the motor is accelerating thus causing the receiver to drop below its voltage threshold and lose contact with the transmitter.
A cheap fix is the receiver cap, a better fix is a stronger BEC and it doesn't matter how many servos but rather how much power they demand. |
Originally Posted by BigRM
(Post 10555039)
Thanks for the replies. I'll add a 10a bec. I do remember reading that the sr300 didn't support 16.5, I'm a noob, (obviously), so I'll run the sr300 at 11ms to start with...I do plan on racing my new FT though, so that might change.
Jay. |
Sorry to bring this back up but did the 10a work? And how do you change the resolution?
Yes, indeed. The CC 10a bec worked like a charm! As far as the resolution goes, that is changed via the transmitter...hope this helps.
Jay. |
Alright, thanks
| All times are GMT -7. It is currently 04:10 AM. |
