Help With Novak Brushless System
I have a Novak SuperSport esc with a SS4300 Novak motor. I am wanting to use a Novak 550 Ballistic motor unless the Novak SS4300 motor will work ok in my SC10 4X4 without being over/under powered. What I am getting at is...will the novak 550 ballistic work with my movak supersport esc with no problems? Also, will the Novak SS4300 motor work ok in my SC10 4X4? Hopefully someone can help me out. I will be very appreciated if you can. Thanks
Unlikely that ESC will handle a high amp draw 550 sized motor in a heavy SC truck
Cheers |
Ok. So how will my Novak SuperSport brushless esc, and the Novak SS4300 brushless motor work in my SC10 4X4?
Motor is not powerful enough and will just get hot
Cheers |
I have a novak explorer 2 speed control and a P2K PRO motor. The esc was acting funny but i got it to work how it is suposed to by the way the led is supposed to light up, but the motor won't run. When i hook the motor directly to the battery it will run. But when pluged into the esc it wont. What is wrong the motor or esc?
| All times are GMT -7. It is currently 08:52 PM. |
