Tekin Programing Question
I just updated my firmware on my RS Pro ESC. It all seems to be working fine but one things seems confusing. Does the TP setting stand for Throttle Profile or Timing Profile? The manual says it changes the throttle curve, but changing this setting seem to change the pre-programmed timing profiles. Is the manual out dated? Im currently running the newest firmware, I think its 223.
Thanks |
Originally Posted by CloseYetFar
(Post 10515822)
Thanks |
Originally Posted by trickedout
(Post 10517686)
Its a little bit of both actually. You have 1-6or 7 cant remember settings. 1 being stock blinky no timing and then 2 through 4-5 are increased with boost and throttle curves. 3 is a linar curve with boost. 5-6 or 6-7 are your custom profiles for you to create via hotwire.
I have the Hotwire but I don't have a PC to bring to the track with me. |
yes whatever you save on your custom profiles are easily accessed by selecting the right TP from your esc...
(Post 10518433)
Thanks for the reply. So the custom profiles will hold both the throttle curve and the timing that I set?
Originally Posted by AreCee
(Post 10519089)
You can create and save two custom profiles on the RS (led 6 = C1 and 7 = C2). Both are accesible by the buttons on the ESC.
That cleared things up for me, thanks guys.
Hey so I was changing the TP setting on the ESC itself from 1 to 3 to C1 and C2. I then verified it with the Hotwire. It seems to change the timing setting but does not effect the throttle curve at all. I set the curve to linear. No matter how much I change the TP setting with the ESC, the throttle curve does not change, only the timing settings change. I think they just need to update the RS manual.
The throttle curve can only be changed by using the Hotwire. LEDs 1-5 are all preset timing; 1 being Blinky.
Go to the Hotwire page and download the guide which explains what you can change and how it works. http://www.teamtekin.com/hotwire_RS.html |
| All times are GMT -7. It is currently 02:35 PM. |
