Glitching Servos
Hi everyone,
just got an issue that has come into my truggy. After the radio gear is turned on for maybe 15 seconds, both throttle and steering servos glitch and play havoc. If I try to do any thing on the transmitter, nothing changes. If I unplug one of my servos (doesn't matter which one) the other servo seems to work fine. Just wondering what the problem could be. A list of my components are: TX: DX3S RX: SR300 Steering/Throttle servo: Hitec 7955TG Battery Pack: Reedy 1600 NiMH Switch: Hitec with charge harness I am tending to lean towards switch or batery pack, what is everyone elses thoughts? |
anyone??
If you never had a glitch issue prior with the same setup then check your battery also if you had a extra receiver and the battery is fine try change this also
glitching servos
i had the same problem at pyscho nitro blast with my truggy. I was running m11 with spectrum module sr300 receiver and savox 1268 servos. Come to find out spectrum tends to glitch when there are several transmitters around. sometimes its the throttle and other times its the steering.
| All times are GMT -7. It is currently 10:27 AM. |
