-   -   SERVO HORN HELP (https://www.rctech.net/forum/radio-electronics/607001-servo-horn-help.html)
dohzer 03-07-2012 08:18 PM
SERVO HORN HELP
with the factory ae horns,which servo horn fits a savox sc-1251mg? i was told the f should fit,but i cant get it to fit:confused:.it seems to small!?
MarkA 03-08-2012 08:12 AM
Yes, it should be the same as Futaba ("F") unless you got a mis-molded one. It's also going to be very tight. On my AE car, I had to really push it onto an actual Futaba servo.
jf+ 03-08-2012 09:20 AM
+1 on the F horn, that's the right one..
Make sure the teeth are lined up correctly. I used a tiny little bit of WD40 on the teeth of the horn itself (not the servo!) and it slid on like buttah. If the horn doesn't line up at 90 degrees, it's better to have it point slighty toward the center of the car, not away - good tip from a local pro.
The alternative is you could pick up a clamping aluminum horn, I believe Racers Edge makes them, and those slide on with zero resistance. They have two screws on either side that you tighten up to clamp onto the spline once you've got it lined up correctly. That's what I'm using now, and it's never going anywhere.
trickedout 03-08-2012 10:38 AM
+1
