-   -   how to charge 2 4s (https://www.rctech.net/forum/radio-electronics/605673-how-charge-2-4s.html)
fordman86 03-04-2012 09:47 AM
how to charge 2 4s
I have moved to 1/8 buggy. Right now I have 2 accucell 6 chargers and thinking of selling and getting one charger. I there a way to balance charge and storage mode the 2 4s packs I have at once SAFELY.
crusey_aus 03-04-2012 10:56 AM
All you need is a parallel charging board
http://epbuddy.com/index.php?main_pa...61nj854b6ool14
Will allow you to charge / discharge up to 6 packs at once on any charger
The faster you want to charge the packs the more powerful charger you will need
Cheers
Dave H 03-04-2012 11:01 AM
Packs need to be reasonably close in voltage before connecting. Most suggest within 0.1V, some go further.
This is probably the safest way, fused and rated for 40 amps:
http://www.progressiverc.com/media/c...95/m/p/mpa.png
Revolectrix Multi-Port Safe Parallel Adapter (MPA)
Progressiverc FMA safe parallel adapter for jst-xh t-plug
More options, not fused and 30 amp rated:
https://epbuddy.com/images/ParaBoard_demo_620px.jpg
EP Buddy ParaBoards
Progressiverc parallel-charge-boards
fordman86 03-04-2012 06:39 PM
Wow those are pricey. How about a good charger that would do both.
nitro_mt_racer 03-04-2012 06:56 PM
Here's a charger that could do both. You'll also need a power supply.
http://www.amainhobbies.com/product_...S-10A-200W-x-2
I use 2 of these and this power supply.
http://www.hobbypartz.com/26p-balancecharger-6200.html
http://www.hobbypartz.com/77p-g350-powersupply.html
fordman86 03-04-2012 07:10 PM
Well I have a 47 amp power supply and just trying to get down to one charger.
