Most Compact Power Supply
Hi all,
Looking for a really compact power supply for ease of lugging my pit gear about, I've got myself one of the pro-spec chargers which are impressively tiny...wouldn't mind a power supply to match now!! |
The size is related to how many amps & what voltage you need.
I run a 12volt 53amp supply that is smaller than a big tissue box. There are a couple of thin ones I've seen if you need less. |
Just needs to run a charger... The charger runs 133w, max 7A. I'll be using up to 4S cells on it, but usually just 2s.
I already have a big setup for charging away from the track, so it's just mobility I am after! Would the much more mini one work? |
| All times are GMT -7. It is currently 12:10 PM. |
