-   -   Tekin RS Timing/boost problems (https://www.rctech.net/forum/radio-electronics/602558-tekin-rs-timing-boost-problems.html)
velotek1 02-24-2012 05:07 PM
The timing/boost seem to kick in for only one or two pulls of the trigger. Then it seems like its back in blinky mode. I'm running a 13.5. I checked sensor wires, all connections, I've tried several batteries. Any ideas? thanks.
BUDRACER1 02-24-2012 06:58 PM
Very possibly a bad sensor board in the motor, weve had this happen a few times. Have you tried a different sensor wire all together? If not try that, then try a different motor, if all that does the same then its time to send the RS in for repair, but id bet on a sensor wire or sensor board in the motor.
good luck
JB
STLNLST 02-24-2012 09:56 PM
Check to see that you are still getting full throtle when this happens. Pull off and go straight to your car without shutting it off. If all the light dont blink then it's not registering full throtle. This could be something as simple as NW settings.
goots 02-27-2012 12:26 AM
after radio calibration you can also raise throttle epa so full throttle will hit just before your radio trigger bottoms out.
Cpt.America 02-27-2012 01:19 PM
What version of the software are you using? This was very common with older versions of the software.
velotek1 02-27-2012 08:35 PM
It ended up being a bad sensor plug on the esc. Thanks for all the help.
