-   -   Receiver Battery Question (https://www.rctech.net/forum/radio-electronics/601425-receiver-battery-question.html)
Square Wheels 02-21-2012 09:52 AM
Anyone know if Hitec 7955 servos work OK with 2S LiPo power or should I use a LiFe battery instead?
I'll be using a Futaba R2104GF receiver if it makes any difference. It's supposed to handle up to 8.4v
AreCee 02-21-2012 09:58 AM
The 7955 isn't rated at 7.4 so you are on your own there. It is rated for 6 volts regardless of the receiver.
Jiggawatt 02-21-2012 05:58 PM
What is the best way to break in a 6.6 liFe Rx battery?
Andy Koback 02-21-2012 06:04 PM
No break in needed. Just run it!!! :nod:
etivac13 02-21-2012 06:08 PM
get a 7954sh instead...it's rated for 7.4V and almost the same specs as the 7955..
Jiggawatt 02-21-2012 06:10 PM
I thought for the first 20 charges they do not like being run under 3.26? They have a tendency to puff or not hold a charge
crusey_aus 02-21-2012 06:22 PM
Nominal voltage of a Life cell is 3.3v so that doesnt sound right
I would keep them above 3v for a couple of cycles, then go for it
Cheers
Jiggawatt 02-21-2012 06:29 PM
What I am saying is that once charged to 3.6 per cell, letting them discharge to 3.26 before 20 cycles, they can easily puff and lose a charge unexpectly.
AreCee 02-21-2012 06:39 PM
Just charge and go. They are sturdier than Lipos. I have two that are three years old and still going strong. I even discharged them below 3V unintentionally and no problem. Both are in my pan cars and take about 50 to 60 mah per heat/main.
Jiggawatt 02-21-2012 06:46 PM
Sounds good. Thanks
Square Wheels 02-21-2012 10:45 PM
Thanks very much for the info. I will probably do an exchange for the 7954.
