-   -   Slash issues (https://www.rctech.net/forum/radio-electronics/599072-slash-issues.html)
SCStephens 02-14-2012 03:16 PM
Slash issues
I am currently running a Slash with mmp esc, stock servo, and flysky GT3b transmitter. I am having an issue where the steering will either work or it won't when the slash is powered on. The throttle always works, but the steering may or may not randomly. I have tried different radio receivers which work fine in my other cars. If I turn it on and the steering works it doesn't quit again until restart.
Has anyone else had this problem?
I have been suggested:
1. Bad servo
2. Add separate BEC
3. Add glitch capicitor to receiver
4. Bad power switch
I would love info from someone who has dealt with this before, but I am leaning toward the separate BEC since everything works over half of the time...
crusey_aus 02-14-2012 04:15 PM
Stock servo should not cause bec issues allthough I wouldnt rule it out
Fit an external bec to take it out of the equation
Cheers
WindDrake 02-14-2012 06:03 PM
I use a FlySky GT3B, and I've got a 6Ch RX in my Slash 4x4. It runs the stock steering servo without issue, this is with the original VXL-3S ESC and now the SC8 I've got in it.
Servo's probably shot.
SCStephens 02-14-2012 07:09 PM
Would that make it work fine sometimes and not at all others?
WindDrake 02-14-2012 07:14 PM
Water/corrosion in the servo, broken wire (break any 1 of three and it'll stop working.), failing servo controller, dying servo motor.
SCStephens 02-15-2012 04:05 PM
Is there any way to test a servo?
WindDrake 02-15-2012 05:59 PM
Plug it into your throttle channel and see if you can operate it with your throttle instead.
porterdog 02-16-2012 07:15 AM
Direct drive on red and black with 5V?
hotrod87 02-16-2012 07:45 AM
NO. Just try plugging in another servo and see what happens.
SCStephens 02-16-2012 09:02 AM
The problem with these methods is it works most of the time and there is no way to tell when it won't work (except right before a race, that's usually when it stops :))
porterdog 02-16-2012 09:56 AM
Originally Posted by hotrod87 (Post 10336876)
NO.
Why not?
