Airtronics older FM/AM receivers
For a 2S 1/10 scale electric, perhaps power the high voltage servo directly from the main lipo. Leave the receiver on the ESCs internal BEC. Other option is an external adjustable BEC for the servo (more complex, but safer in case you might throw in 3S for a speed run). Adjust the BEC as desired for the servo.
For anything above 2S, say 1/8 electric, use an external adjustable BEC for the servo.
Use or rig up something like this to hook up the servo:
High voltage Servo Connector
For a nitro, go the other way, use an external BEC for the receiver. Wouldn’t need to be adjustable or very big, very little power consumption.
Another option for all would be using a diode setup to drop the voltage for the receiver. The voltage wouldn't be as well regulated, but would probably work OK. Probably cleaner power than a switching BEC as far as noise and ripple and such.
Must always avoid mixing the 2 power sources/voltage levels.
Safe to assume you want the higher voltage for the servo? If so one option is separating the power sources for the servo and receiver.
Certainly the cleanest way, if you can find one. I used the AM job back when, worked great, still does even. In one of my Vintage cars now.
No. The trick is in the connections, can be a little complex, have to consider ground, etc. Can help if needed.
Good luck!
Good luck!
